Reading the dimmension of string array
How can I read the dimmension of an automatically generated (from /directory command) string array parameter?
I would like to save the dimmension into a variable.
Thank you very much!
Alex
RE: Reading the dimmension of string array
*GET,<result_param>,PARM,<queried_param>,X,
should restitute the dimension of the ROW dimension of the array (dimension "X" or "1").
Of course you have to know he name of the queried parameter (the array).
Thanks cbrn!
You forgot to type DIM:
*GET,<result_param>,PARM,<queried_param>,DIM,X
Alex
