view from 3D
view from 3D
It may be the easy question but can someone explain how to use command "view from 3D" under Catia v5 drafting mode?
Its been a long time since I used V5 so step by step will be helpful.
RE: view from 3D
RE: view from 3D
I have a model that contains only wireframe geometry. I can create a view from 3d which contains all the appropriate wireframe geometry, however I lose all of the graphic properties associated with each element.
Example, a curve in the 3d model is thick and dashed. When I make the view from 3d, the curve appears with the default thickness and solid.
How can I keep the 3d graphic properties for an element on a view from 3d?
Thanks.
Using v5r16
RE: view from 3D
RE: view from 3D
RE: view from 3D
