Replacement Core for Latching Relay
I use a latching type relay for a faulted circuit indicator. When a high fault current is sensed the pulse magnetizes a core that pulls a latch down and turns an orange flag to indicate the fault. When power is restored the magnet is pulsed in a different direction to demagnetize the core. The core that is currently in use is a vacozet 258 magnet with a coercivity of about 26 Oe, but I am no longer able to get this magnet. Would anyone happen to know of a magnet at a reasonable cost with a coercivity similar to this.
RE: Replacement Core for Latching Relay
Switching to an alternate material can be done, but I doubt if there is a drop-in replacement available. It'll likely the geometry will have to change and it'll take a few iterations to find something that'll work.
Can you give more info?
Plesae read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
