Opening "View Only" than asked to "SAVE"?????
I may just be venting here but does anyone know why you are promted to "Save Changes" to something that was opened "View Only" and no changes were made???  Sick & tired of wasting time with rediculous clicks.
Bloodclot :(
***** Fear not those who argue but those who dodge *****
Dell Precision 670
3.0 Ghz Xeon Processor
Nvidia FX3450
3 gig of RAM
Dual 19" Viewsonics
RE: Opening "View Only" than asked to "SAVE"?????
Do you have auto-save on? If not.... go to tools, collaboration... and look at the last 2 check boxes...
Go Honda!
I have the "Enable Multi-User Environment" unchecked.  This makes the 2 lower options non-active (greyed out).
Dell Precision 670
Nvidia FX3450
3 gig of RAM
Dual 19" Viewsonics
Try Tools > Options > System Options > External Refences and check Don't prompt to save read-only referenced documents (discard changes)
If it's already 'checked', try unchecking it.
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
Along the same lines, try opening a drawing, printing the drawing, and then closing. What exactly does it think it's saving?? Stupid.
Could it be related to the new version and that not all of the opened files have been saved in the new format yet?
8Complex  -  The new print settings.
Remember...
       "If you don't use your head,
                   your going to have to use your feet."
CBL is correct! This is a known bug in SW07. CBL has provided the correct answer that should fix the problem.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
