NX4 crashing when starting thread feature - anyone have a solution
We are currently testing NX4 and are experiencing a really bad crash. (UG closing fatal error)
To reproduce - start a new file, enter modeling, select Insert - design feature - Thread, UG crashes.
Anyone have the same problem. (32bit xp - NX4.0.2.2 MP3)
We currently have a PR in with UGS critical 1
Peter
London, Ontario, Canada
Peter
RE: NX4 crashing when starting thread feature - anyone have a solution
John R. Baker, P.E.
Product "Evangelist"
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
If you do releoad NX4, try the problem sequence with the OOTB settings, no company customizations or settings.
Ben Loosli
Sr IS Technologist
L-3 Communications
You are on the right track pointing to the customer defaults Ben! Good thinking.
UGS has contacted us about a corrupt customer default file
created when importing customer defaults from NX2 to NX4.
We have removed our current default file and solved the problem. I big thanks to the GTAC support team.
Peter
