1/3 Stress Increase History
With the 1/3 stress increase being phased out, I began to wonder exactly why it came about. So far the research I have done still has not given a definative answer on how the stress increase came about. Doe anyone know the history of the 1/3 stress increase or a good reference on the topic? Thank you in advance for your assistance.
RE: 1/3 Stress Increase History
See article by Duane Ellifritt entitled "The Mysterious 1/3 Stress Increase."
costs $10 for non-members of AISC.
Try www.aisc.org/stressincrease
Dealing with the 1/3 stress increase, I have been working on a project which has been peer reviewed. The project is in IBC 2003. The reviewer has told me they have taken a 4/3 increase on the allowable bearing pressures in the geotech report. I scoured the IBC looking for where you can do that, but found nothing, however the reviewer insists his design "savings" due to smaller foundations with the 4/3 increase is code compliant.
Have any of you seen anything like this allowed in the code?
Is anyone aware of a failure being attributed to use of the 1/3 allowable stress increase?
movement and the duration of maximum loads due to wind or seismic event is short.
Allowable bearing pressures for clay soils are usually chosen on acceptable settlement criteria.
Not sure if this applies to sands/gravels though.
