Catia V5 Display Problem
Hello all. I am having a problem with the display on V5. The specification tree(f3) does not appear on the screen at all. The scroll bar is all that shows when toggling with f3. Also, if I click and drag in the draw area the window that it creates stays on the screen untill I pan or do something else. Seems like a display problem. I have a GeForce FX5200 adapter and have the most recent driver fron Nvidia. Anybody have any ideas as to what could be causing this?
RE: Catia V5 Display Problem
click the axis (lower-right corner) to make the tree active (model geometry should dim), and click the FIT-ALL-IN icon to fit the tree to the screen.
If that doesn't work, click the axis again and click the FIT-ALL-IN again.
After you get the tree back, click the axis to make the model active
Click the little axis located in the bottom right of the screen, and do the 'Fit all in'.
I haven't bothered to check, but is that a supported video card?
Catia Design|Catia Design News|Catia V5 blog
http:
Derek
