ACAD 2006 - Block attribute editir
I made a block with four attributes and all is fine. However when I put in values in the attributes the 'Enhanced Attribute Editor' box is always too small - shows only 2 lines so I have to scroll to the others and its always on the right hand screen.
I have tried using the windows hold down control or shift control on exit but this doesnt help.
Is there a way to control the size of this editor? (and position).
Cheers. Sean.
RE: ACAD 2006 - Block attribute editir
Did you hover over the corner and stretch the dialog box?
"Everybody is ignorant, only on different subjects." — Will Rogers
Thats the frustration - once is fine but when its 30 or 40 times a day it gets tiring.
Is it possible to keep the thing stretched for next time?
Cheers. Sean.
I think you can edit this in the registry. Normally this is stored. Mine is HKCU >> Software >> Autodesk >> AutoCAD >> R16.2 >> ACAD-4005:409 >> Profiles >> <VANILLA> >> Dialogs >> AcEAttEdit. Yours may differ some but it should be found under the profile you are using. Changes are immediate.
You are officially the winner, pat on the back and all that. Top stuff.
Cheers. Sean.
