ground rod resistance
is there a way to check the resistance of a ground rod other than using a ground rod resistance meter,thanks--bob
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: ground rod resistance
Although Megger makes ground resistance testers, this is not the same as a "megger" insulation resistance tester. In short, you can use a Megger ground resistance tester, but you can't megger your ground rod.
Do you need to do this in order to improve the resistivity of the soil? To add more ground rods?
The three point fall of potential may work. I assume your in permafrost, if so your time has to be pretty cheap to set up the system in ground that's harder than concrete.
