Rectangular Vessel
Rectangular Vessel
Rectangular Vessel
I need to do some calculations on a rectagular pressure vessel. I don't think that there is anything in ASME Sec 8 Div 1 on rectangular vessels. What would be my best course of action. Really all I need a wall thinkness calc for square vessels. Any suggestions???
RE: Rectangular Vessel
Newfie-
I'd suggest you read Section VIII Div. 1 Appendix 13. Let us know what you find...
jt
Why the heck would you be building a rectangular pressure vessel anyways?!!
Is this a "newfie" joke?
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
I have seen a number of these over the years. Mostly small,double walls with stays.
Besides havn't ya ever seen a "wood" stove?
The headers for fin-fan heat exchangers have been rectabngular for decades and are designed, manufactured and stamped per ASME VIII, Div.1.
If you look at offshore platforms, you'll find a lot of rectangular tanks. There space is at a serious premium, and extreme steps are taken to limit space requirements. Among those steps are the use of rectangular tanks (for atmospheric/low pressure tankage).
I've seen several inquiries on rectangular vessels here, and it seems they tend to be rectangular containers of various kinds, not necessarily proper ASME pressure vessels.
Thanks guys, and my apologies NewfieEng.  All my experience has been with ASME code vessels which, under the pressures I see in the power industry, need to be circular.  I never realized there were applications where someone would build a rectangular pressure vessel.
I have learned something today.
Patricia Lougheed
vpl, it can be done.
We have over 50 rectangular vessels (4'x 8'x 10") in operation designed for 125 psig @ 850F. The internals that act as stiffeners are 4130 castings designed for 2500 psig @ 850F. Some of these vessels are 50 years old with an on stream utilization of better than 99.9%.
We also have 17 jacketed SS vessels where the core is two overlapping circles, the cross section is a figure 8.
All ASME stamped.
Air cooled heat exchangers are commonly known as fin-fans. This is a case where a trademark has become a universal name kind of like a self adhesive bandage is more commonly known as a band-aid. I don't know how much of the market Hudson owns, but I'd guess its a substantial fraction. They have a pretty good web site http://www.hudsonproducts.com/industry.html which indicates that their products are used in power generation, among others. I have a refining background and dealt with them on a regular basis.
jt
Thank you JTE that was exactly what I needed. I had overlooked that section when I went looking the first time. I was in too much of a rush. But I have since Pulled out the book (ASME Sec 8 DIV1), made all the calculations and even created a little spreadsheet to do the calcs in the future.
In fact these are calcs on a Air cooled heat exchanger. tHe sections are rectangular and have plugs all down both sides and tubes running through the middle. Not your average pressure vessel.
