Best Software for a Newbie
First off, great reference tool this forum is... I apologize if I overlooked the answer to my question but here goes....
I just started my excavating business and after 15 yrs. of working in the dirt for other people I now need to learn the ropes of running my own business as far as the office work goes.... I have been researching Take-Off Software but am confused about what to buy.... have been receiving ITB's for small commercial projects ie; carwash, auto parts store, small office building, etc.. and want some help in the takeoff procedure.... of course $$ is an issue but I also don't wan't to buy something that is too limited in it's abilities should my businees continue to grow... Thanks in advance for anybody's help...
RE: Best Software for a Newbie
Be sure you hire someone you can trust to give you the correct quantities and who will also keep your info private.
Get references on anyone you are considering. Ask them what software they ar using, get graphic reports (3-D and xsect) to make sure the data was entered correctly. A good estimator will alert you to potential problems with a particular project, i.e. dirt thar has to be moved more than once, plan errors, potential change orders, etc.
Good Luck
