sheet 2 format
sheet 2 format
In 2006 drawings, when I added a second sheet I was able to have the second sheet default to my second sheet format. Now that I have 2007 installed it no longer defaults to my second sheet format. Either I have forgotten the right way of setting this up or it has changed in 2007. Any ideas?
RE: sheet 2 format
Pick "Always use these default document templates" instead of "Prompt user to select document templates".
SW07 SP1.0
Flores
RE: sheet 2 format
Before you always upgrade to a newer version:
Start/All Programs/SolidWorks/SolidWorks Tools/Copy Options Wizard. Save the settings to a location where you can find it.
After upgrading, restore this file (same steps).
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
RE: sheet 2 format
I have to right-click the drawing and choose the drawing size there (A or B). Is everyone else having this problem or is it just a hidden setting I haven't found yet?
Flores
RE: sheet 2 format
A simple workaround for this was to create a new drawing template (.drwdot) with multiple sheets. Then the "Add sheet" function works as per normal.
RE: sheet 2 format
Flores
RE: sheet 2 format
Just open the Template file (Example B-SIZE.drwdot)- goto -File -save sheetformat- save the file (Example B-SIZE.slddrt). This file should be same path where the *.drwdot files are maintaining and give the same name.The file extensions are only different.
now goto
option- file locations- sheet format- select the path that just created the *.slddrt files
now if u add 2 nd sheet in drawing u can get the 2nd sheet default.
regards,
Murugan.S
India.
