Light Switch with contactor
I am trying to find a light switch, with two momentary buttons (ON) & (OFF). But also with a contactor which could be controled via ac output card. Building a new home and using a new 1756-L55M12 to do the automation, but having trouble finding a suitable light switch.
thanks,
james
RE: Light Switch with contactor
There are rocker switches available, the kind used for low-voltage lighting control.  At one time, larger buildings were often wired with 24V control and then a bunch of contactors at a central location to control all the lighting.  A 3 position ON/OFF/ON momentary rocker was often used for each switch.  Would this serve your purpose?
Nic Van Engen
Electrical Technician
I have installed several light switches in our plant using just a single pole momentary contact. It is programmed so when the button is held for  more than 1 second the lights go on and if it is just touched the light goes off.
