RE: SMD Resettable Fuse
I need everyone to help, please help me find a Surface Mount resettable fuse that will hold up to 2.1 amps @ 28 vdc, most of the 60 volt SMD fuses that I have found drop to 6vdc at that current. The application is to install this fuse in line between the 28VDC source and the load.
RE: RE: SMD Resettable Fuse
I have checked schurter and their SMD part will not maintain the 28V at 2 amps, but the leaded part will. I need a SMD part for my app.
