Placeing componets with keystrokes
I am trying to assemble parts using only keystrokes, and am having trouble. I can get to assemble components, and bring the correct part into the assembly. However, I can not figure out how to select the planes that will be used for placement. Any suggestions will be appreciated.
RE: Placeing componets with keystrokes
<Alt> I C A <Enter> (this picks the default selection for insertion)
<Alt> <Alt> <Tab> (drops you into menu tree)
Arrow down to feature (right arrow to expand subassemblies)
<Space bar> to select (ie. a plane)
<Ctrl><Alt> jumps you back into the component placement window
<Enter> moves you to the next constraint; repeat selection of assembly constraints
Not sure how you are going to select constraints from the component being assembled.
<tg>
<Alt> E F
Search for all planes in the part, and select the one you need, or, if you know feature ID/Name, you can narrow down your search.
Tofflemire
