2007 SP1.1 Available
Got it and installed it this morning.
RFUS
RE: 2007 SP1.1 Available
Thanks for the heads-up (star)!
However, remember what Scott said a million times last week:
"If it's not broke, don't fix it!"
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
Have you found what the fixes are?  I can download the sp, but the fixes are not listed at the SPR List and Lookup.
SW07 SP1.1
Flores
What are you trying to say Jeff? - I talk to much!! haha lol
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Yeah, definitely.  thumbsup2  And sometimes it's worth paying attention.  bigears
Jeff Mowry
According to the SW website, only those users who are running 32-bit SW on a 64-bit OS need the SP1.1 upgrade.
Yes I just found that and think it might cause problems for those that update to 1.1!
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Yikes, PDMAdmin is correct.  I do not know if it would screw up my install if I just updated SW without reading the tech-alert (which is where the info is).  It should be noted in the download section instead of a tech alert.
Quote:
SolidWorks 2007 SP01.1 is LIVE on the web
Note: This update is only necessary if you run the 32bit version of SolidWorks on a 64bit OS (Operating System).
SW07 SP1.0
Flores
If it does ,then rollback to SP1.0 - Just restart the 1.1 Download and select Rollback.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Haven't run into any problems running SP1.1 in win32. Everything seems very stable.
Well they don't give the option to DL just SP1.0 either, so that's really screwed up... they give such a bulletin like that then you only have 1.1 to DL... Iguess that was their intention, but that just seems "As backwards to me".
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
