Source of Corrosion on Cast 316 Stainless Steel Valve
We have a 10" rotary valve that handles a dry pharmaceutical solid. The valve body is cast 316 SS and the rotor is 304 SS.
We have seen surface corrosion on the interior surfaces of the valve inlet. It almost looks as if that portion of valve body is carbon steel clad with 316 SS. The rest of the valve body (rotor chamber, flanges and outlet interior surfaces) and the rotor itself are pristine. The 316 SS Equipment immediately upstream and downstream of the valve are also corrosion free.
What could be the reasons for this local corrosion? Why would it not appear on other areas of the Valve? Is it possible that something went wrong during the casting of the valve?
RE: Source of Corrosion on Cast 316 Stainless Steel Valve
We have better than a hundred rotary valves at our site and it has been our experience that the body castings haven't been the prettiest especially in the throat area near the flanges.
The problem is mainly shrinkage in this area and usually has the appearance of "mud cracking" This can be very light or in the form of canyons and rivers. The irony of this that one of the better operation rotary valves has the worst problem.
Look into what else is different in that location. Little things such as temperature, moisture, airflow can really add up to change the local conditions.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
