parametric design
parametric design
hello helpful people,
I'd like to know how I can create a design formula in catia v5, where I can 'say':
If 'length.1' >= 3000, then 'value=60', else 'value=50'
In my language: if my pallet's width is bigger than 3000 millimeter, than my axis diameter must be 60 mm, if my pallet's width is smaller than 3000 mm, my axis diameter must be 50.
The pallet and the axis are different parts.
i think its enough information for my problem,
with kind regards,
R.
with kind regards,
R.
RE: parametric design
The syntax would be something like:
If 'length.1' >= 3000mm {
value=60mm
else
value=50mm
If you don't have a KWA license then you may find the cheat on this site useful:
htt
