ETABS / Column with no stiffness
In ETABS, how do you produce a column with zero stiffness?  Thank you.
RE: ETABS / Column with no stiffness
Also try forum802.  Just note that you have also posted the same question in this forum if you do.
What kind of stiffness - axial or flexural?  Either way just set the member property modifier for the behaviour you are interested in to an insignificant number.
I want a column to have zero flexural stiffness.  I want all the shear to be taken by the shear walls.
ok set the moment of inertial modifiers low
