Corrosion inhibitor for atmospheric cooling water system
Can anyone advise on Corrosion inhibitor for atmospheric cooling water system.
Max temp - 80 oC
Min temp-10 oC
Water Volume - 5 m3
S.S pipes
Thanks in advance.
Max temp - 80 oC
Min temp-10 oC
Water Volume - 5 m3
S.S pipes
Thanks in advance.
RE: Corrosion inhibitor for atmospheric cooling water system
Search the internet on "cooling tower" chemicals..
Contact NALCO..
http://ww
We, collectively are helping you.... So be polite and complete this thread.... Tell us about which chemicals you decide upon...
In what country are you located ?
-MJC
what materials contact the water?
Thank you all for your replies...
http://eng-tips.com/threadminder.cfm?pid=164
how bout a star, then ???
-mjc
