high temperature hot water
Just a quick question - when using high temperature hot water what type of valves do you typically use? Butterfly or Ball? Sorry if this is a silly question.
RE: high temperature hot water
susanp,
What is the temperature of the hot water?  What size valve is it?  What presssure is the water?  How much leakage can be tolerated?  Is this for shut off or control?
Good luck,
Latexman
