Edrawings measuring precision
I'm using eDrawings '07 Pro. When using the measure tool, I know there is a way to change units but is there a way to change the decimal place precision?
Anne Van Epern
C.G. Bretting Mfg., Ashland, WI
www.bretting.com
SW 2006 SP4.1 DBWorks 2005
Quadro FX 3000
Pentium 4 3GHz 3GB RAM
WinXP 02 SP2
RE: Edrawings measuring precision
Have you tried saving an eDrawing out with differing drawing/assembly/part precision set within the SW files?  I wonder if it just assumes whatever was used withing the SW files.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
That was my first thought, however, if I open the .sldprt in solidworks, the decimal may be carried out 3 places. Example 1.909 and 1.000 and 1.640. Then when I open the .eprt file in edrawings they display as 1.91 and 1 and 1.64.
Anne Van Epern
www.bretting.com
Quadro FX 3000
WinXP 02 SP2
You should ask your VAR maybe they'd know?
Or if that fails your CAD "Administrator" would know for sure....
I AM the CAD Admin.
