GRIP to import part from TcEng
Some time ago I used a grip programme to import a part which was stored on Teamcenter Engineering using the UG manger encode command within GRIP.
however, I have forgotten the exact syntax i used to wild-card the item revision to use the latest.
To make matters worse I havent been able to find my original source code (it was some years ago!!)
Anyone got any ideas?
Cheers in advance.
