Autocad commandline
Autocad commandline
What is the difference between the following on the command line:
zoom
_zoom
'_zoom
I have a friend who is learning Autocad from a book and she is curious as to what these notations mean (and why they produce the same result).
zoom
_zoom
'_zoom
Cheers. Sean.
RE: Autocad commandline
zoom is the command in the language of your acad-version.
_zoom is the englisch command.
Example: _line = linie (German)
'zoom is the transparent command. You can use it during an another command.
Example: _circle -> 'zoom -> ...etc
try it without the apostroph _circle -> _zoom
HTH, Lothar
ADT 2004
ACAD 2002
