Pipe & CB Storage
Pipe & CB Storage
Can't model storage from pipe and CB interconnecting two ponds. I have a parking lot with two subcatchments. A CB at the bottom of each basin. First pond flows to second via a pipe (culvert). Downstream CB has a vertical orifice restrictor plate at outlet invert. When I add the pipe and CB's for storage volume I get major oscillations. What am I doing wrong?
RE: Pipe & CB Storage
Your "pond" can have a separate line in the storage table for each of the contributing volumes (above-grade, connecting pipe, CB, etc.) In the outlet table, just list the restricting orifice.
CAN A PRISMATOID CATCH BASIN HAVE TWO SEPARATE CULVERTS with different invert elevations,locations and sizes?
This would allow controlling the outflow , both in magnitude and direction to different washes.
Which is primary and secondary?
i.e. 2 primaries and 2 secondaries?
