Load capacity of Aluminum tube
I am considering building some aluminum ramps, that would be 5ft long. I was planning on making them out of 1 x 2 x .125 6061-t6 Tube. Each ramp would have three tubes running the 5ft length and have crossmembers joining them and then a .125 piece of Floor Plate over them.
My questiion is what is the capacity of each tube or even better of the three combined. The ramps would be supported at each edge so it would be a 5ft span.
Long time ago I had found some charts that had similar information but for the life of me I cant find them.
Thanks alot.
If no chart exists and their is a formula that will do the job.
Thanks alot.
RE: Load capacity of Aluminum tube
Generally these forums are not for this type of endeavor; however, I'm sure several will bite on this one.
thanks
Mike Halloran
Pembroke Pines, FL, USA
fcy for 6061T6 is 36ksi
allowable moment is 8238 in.lbs.
the tube is 60" long, assume a point load in the middle
allowable shear load is 8238*4/60 = 549 lbs
if you use a safety factor of 3, then the allowable load for your assembly of 3 tubes would be 549 lbs; this assumes all tubes are equally loaded which is not obviously the case.
this assumes your floor plate is ineffective. its effectivity depends on how well you connect it to the tubes (weld?, 'cause you're using 6061).
you also need to think about the floor plate itself. it distributes the load to the tubes. say a load of 500 lbs is applied at two points (2*250 lbs) on the ramp (a small trolley) say 6" apart, centered on the ramp. the outer tubes react 1/2, 125 lbs; maximum moment is 125*3" = 375in.lbs; stress is 375*6*64/w = 144000/w psi ... so if this floor plate is steel, you need to have 2" effective width (with no safety factor) ... ha hummm a bit dodgy, but then your cross members will help ... from the look of it it should be ok (1/8" steel plate supporting 500lbs, two heavy people ... sounds reasonable.
rememebr the 549 lbs is normal to the ramp, so the allowable weight would be the vertical component 549*.866 = 476 lbs; the horizontal component would be the effort to push the weight up the ramp.
like mike posted above, it probably be easier to buy one rated for your load.
Just for future reference how did you get the 8238in.lbs from the information you had and also is their a chart or list of different tube sizes and amterials.
thanks
stress = moment/section modulus
so allowable moment = allowable stress*section modulus
=36000*0.23
The welding rod must be selected with heat treat plans (some fillers undergo undesirable changes if subjected to heat treatment) and final finish in mind (some fillers will change color during anodizing).
Cheers
