extude_17 in entirely inside the model - model unchange - help
I have a solid that I am extruding, the sketch is a rectangle and smaller than the entire part. I have tried extruded up to, next, selected surface, blind, everything but the software keep telling me that the protrusion is entirely inside the model. In the preview the solid is outside of the model extruding towards the part; if I use blind it goes through the part. the new feature is completely inside of the part, I can see it. Does anyone have a clue what this means. I have had this before and I can't remember what to do to fix it.
thanks Texaspete
thanks Texaspete
RE: extude_17 in entirely inside the model - model unchange - help
Hope this adds some insights.
Texaspete
Another way to do this would be to create the rectangular extrusion as a Surface with blind depth and check off the capped ends option. Then select the Closed Quilt and hit Solidify and Remove material.
Michael
