Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site is one of the cleanest and BEST forums that I have seen. I have sent quite a few people your way. Keep up the good work!!!"
Geography
daniels11 (Industrial)
16 Oct 06 19:17
i have question about pronest , somebody has a manual or instructions ??
thanks
Helpful Member!  Darken99 (Mechanical)
19 Jan 07 16:38
What do you want to know?
20 Jan 07 16:20
some actions in this program are complicated ,like common line cut , can't change starting point , the pierces when you use a vsp file or when use the option with parts already creates as doble in pronest are too long and i didn't find the way to change.
thank you
22 Jan 07 16:08
First, the reason you can not change starting points is usually because of the cutting order. It is setup so that both parts are cut with 1 pierce point.  You can sometimes get different pierce locations if you line up the 2 objects you want, select them both and click on the common line cut icon.
As for changing the pierces, do you mean objects with multiple pierces?  If so right click on them in the Parts list and click on advanced edit.  This will allow you to change the cut order for parts.  Just remember you want your part connected to the material it is cut from until all other internal cuts are made.
Close Box
Join Eng-Tips® Today!
Join Us             Close
