NOx reduction
NOx reduction
NOx reduction
I am wondering if anyone has any experience or knowledge on the low temperature oxidation of NO to N2O5.  The technology is trademarked as LoTOx.
I have looked at SNCR and SCR in the past and found a lot of material in journals and online.  However, with LoTOx I seem to be hitting a dead end.
I am looking for information relating to disadvantages or limitations with the system.  Is ozone too expensive?  Is it limited by the NOx levels entering the unit?
The best information I have is done by BOC.
Cheers
RE: NOx reduction
Our site is looking into the LoTox Technology for NOx reduction. Our NOx is generated both by HNO3 manufacturing and an HNO3 oxidation of organics.
The site currently uses thermal and modified SCR, both very expensive to operate.
I called the person responsible for the evaluation and was told that he has take a position in technical sales, smart move. The person filling in didn't know anything as he hasn't done his own evaluation, they didn't seem too enthusiastic about the new project.
You might want to checkout this source.
http://www.belcotech.com/products/nox.html
RE: NOx reduction
You can use hydrogen peroxide for low temperature oxidation of NOx to nitric acid.  The reaction in aqueous solution is
   HNO2 + H2O2 -> HNO3 + H2O
The hydrogen peroxide can be added directly to nitric acid pickling solutions to prevent the escape of the nasty reddish NOx fumes, plus it regenerates some nitric.
Or, it can be used on cooled flue gases, as nitric is more easily scrubbed than NOx.
The limitation is that hydrogen peroxide has a relatively short life (self-decomposes) above about 50oC.
RE: NOx reduction
The LoTOx system I was looking at was ozone and not hydrogen peroxide, although I'm sure there are different types.
I am curious as to why I have not seen more information on LTO.  In our application now we have fairly low NOx already and we do not need a wet scrubber, so I would suspect that a system such as SNCR would work best for us.  But I am having trouble convincing people without any information on LTO.
RE: NOx reduction
I have also difficulties to find information. However, it seems that from this page you can order some information (LoTOx is the last thing at the bottom of the page).
http://www.belcotech.com/techlib/index.html
