AutoCAD - Grid Lines
My current firm uses grid lines that do not go through the entire structure. The generally stop the grid lines at the structures extent. In general, other places I have worked took the grid lines through the structure to pass through all columns on the grid line.
While I understand the bases of both drafting techniques, which way do you show the grid lines?
RE: AutoCAD - Grid Lines
Not sure what benefit is derrived from stopping the column line short of passing through all the columns that are on it?
