Extruding Projected Curve
  I have a cylinder body in which I projected a sketch profile onto it.  How can I get the projected curve to extrude or subtract onto the cylinder body and maintain the projected profile?
Jason Misztal
Power Tool CAD Designer
Marquardt Switches Inc.
www.switches.com
Syracuse, NY
RE: Extruding Projected Curve
Jason,
You could probably use Subdivide Face to create a surface on the cylinder bounded by the projected curve. You can then select that face as your extrusion reference and extrude it by a distance or upto a surface reference.
Another way would be to just extrude your planar curve profile upto a surface offset from the cylinder face.
There are also probably a few more ways.
There are many ways to skin a Feature.
Michael
More, because not sure about the shape you want.
After mjcole's recommended Extrude - Offset Surface of outer face, trim extrusion to create a cylinder floor.
Extract Sheet, Trimmed Sheet, Thicken then Subtract.
Will pocket work?
If your sketch is projected straight along a specific vector, why not just extrude the sketch along the same projection vector until it intersects the cylinder, then subtract or trim body?  I would think this would be no different than projecting curves unless there's a wrapping involved somehow.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
