PDMWorks service stops
I had to reinstall PDMworks server and now the pdmworks service on the server will not stay running. It starts but is almost immediately terminated. I saw this when I first installed, but I can't locate the solution.
I need a solution..no one can work!
Craig Sink
Mechanical Engineer
Force Design, Inc.
RE: PDMWorks service stops
Is it running with the right privileges? I need to run my pdmworks server service as a user that has access to the network share the vault is located on.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
Are you getting an error message or is it just stopping?
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP1.0, Dell M90, Intel 2 Duo Core, 2MB RAM, nVidia 2500M
Thanks Stefan,
That fixed it. I set the service to run as the administrator on the server and it's running fine now. I'm not sure how it worked before, but it did. The important thing is its working now.
Thanks for the help,
Craig Sink
Mechanical Engineer
Force Design, Inc.
