Laser scan file convert to dwg file?
How do I convert an ascii file to dwg file?
RE: Laser scan file convert to dwg file?
1.  Use awk, sed or some other stream editor to get it into the correct format, paste it into a DXF file, and open that.
2.  Similarly, turn it into a script, and feed that to AutoCAD's command processor, as if you were entering individual points from the keyboard.
3.  Buy a converter.
Mike Halloran
Pembroke Pines, FL, USA
