Creating the model of an input (text file)
I have an input ABAQUS file (text file).. is there any way to get the CAE ABAQUS model of this file without re-creating the model of this file
RE: Creating the model of an input (text file)
corus
Hope this help.
sendy.
I think what Corus meant was that you only get what's in the .inp file as you listed, you don't get the actual "model" itself, i.e. you do not have the geometry that was used to create the mesh. Thus if the OP wanted to change the mesh, he would have to recreate the geometry from scratch.
1) the file is save with an .inp extension.
2) you are doing File - Import - Model (*.inp)
I ever had that problem. Try to name it by writing *.inp when you're going to save your input file and select "all files" for file type.
Another way is by copy your old input file, open it then write your new input data there. When you save, doing it with "all files" selection in the file type option.
Hope this help.
regards,
Sendy.
You will probably find that the file is called index.inp.txt - Notepad has 'helpfully' added the .txt extension for you. To check this, make sure that you have "Hide extensions for known file types" unchecked in Windows Explorer - it's in "Tools > Folder Options".
Then it's just a case of renaming the file in Windows Explorer to index.inp and you're good to go.
Martin
