Colored piping in water treatment plants.
I am looking for a listing of what color certain pipes should be colored in a treatment plant. I was told raw water pipes are red but have not found that stated anywhere. Any help would be greatly appreciated.
RE: Colored piping in water treatment plants.
pump2005
usabluebook has a copy of the ten states standards in their catalog, link below
https://usabluebook-onramp.com/docs/images/792.pdf
but check your state, I know some states require marking in accordance with ASME boiler code which have labels according to hazard level: white on green, no hazard; black on yellow, hazard; white on red, fire system.
Hydrae
From Article 2.14 of the Ten States Standards
Water lines
raw or recycle  olive green
settled or clarified   aqua
finished or potable   dark blue
Chemical Lines
alum or primary coagulant   orange
ammonia  white
carbon slurry  black
caustic  yellow with green band
chlorine (gas and solution)  yellow
chlorine dioxide  yellow with violet band
fluoride   light blue with red band
lime slurry  light green
ozone  yellow with orange band
phosphate compounds  light green with red band
polymers or coagulant aids  orange with green band
potassium permanganate  violet
soda ash  light green with orange band
sulfuric acid  yellow with red band
sulfur dioxide  light green with yellow band
backwash waste  light brown
sludge  dark brown
sewer (sanitary or other)  dark gray
compressed air  dark green
gas  red
other lines  gray
I believe the American Public Works Association (APWA) is also an entity that publishes a "Uniform Color Code" that is sometimes used to temporarily etc. mark at least some underground utility lines (you could see much about this in a web search, e.g. colorful depiction at http://www.pp.okstate.edu/ehs/KOPYKIT/APWA%20Uniform%20Color%20Codes.PDF).
Where are you located? the pipe colors are sometimes regulated by local laws. The answers above probably are related to USA.
rgs
Thanks for the responses. I am in NJ.
Pump2005
NJ is one of the ten states...
Hydrae
Thanks hydrae. usabluebook has a great listing and covers about everything water and chemical I have.
