How do you create an assembly from anther.
Hi guys,
I'm a new Solidworks user. I'm transitioning to Solidworks from Catia. I was wondering if there is a way to create a new assembly from an existing one and keeping all the links.
My goal is to have a standard asm file and its sub-asm's and drawing files attached. Using that to create new asm by renaming the file and drawing files to new name. I'm having problems with th links. It ref's the old documention and I only want it to see the new one.
For you who know Catia v5. The command sent to directory. The file will go and take it's linked documentation and give you option to rename your files as target name,breaking your links too the old documention.
Thanks Catusr
Thanks Catusr
RE: How do you create an assembly from anther.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Example:
1) Copy and paste (ctrl-v) "assembly_one.sldasm" file
2) "Copy of assembly_one.sldasm" will appear
3) Rename the new file and then you can work from there while keeping the links.
Keep in mind you must work from the same directory as the old/master assembly otherwise you'll need to relink the entire assembly.
Check out the Pack and Go function in SW2007. It will create a copy of a project and rename (replace portion of part name) selected components and handles all the component references in one easy dialogue box.
