Wildfire 2 Questions
Hi all.
I have just started using WF2. I used to use 2001 and I am trying to locate the commands I like using but I can not find a few, wondering you guys can help?
1) Show supressed items in model tree (it was already set on my old machine)
2) Repeat assembly in assembly mode (very useful for fixings etc)
3) In drawings independently keep certain tan lines and then switch tan lines off which erases the ones I did not want to keep.
I am probably being dumb not knowing the above but I cant find it!
AD
AD
RE: Wildfire 2 Questions
2) Highlight the component on screen, select EDIT, REPEAT in the file menus.
3) Pick the drawing view on screen, and pick VIEW, DRAWING DISPLAY.
http://www.sprdesign.com
http://www.3dlogix.com
These normally show at the site
http:
which usually shows up in the Pro/E browser when you launch Pro/E.
Pro/ENGINEER Wildfire Menu Mapper
h
For 2001 menus here are the direct links.
Assembly
ht
Part
http://w
Drawing
http://w
Michael
AD
