What is st6wf13.5? What is the flange/web size?
I have a drawing that calls for:
st6wf13.5x7'-2 1/2"
and
st15wf54x25'-11"
From the machinery's hand book, I am pretty sure it is  structural "T" and it is, 6 and 15 inches in height and 13.5 and 54 lbs per ft.
My problem is I have searched the hand books that I have and the internet but I can't find the dimensions of the flange and web.
The building was erected in the 60s in Canada. Some of the steel is from Scotland.
Any help would be appreciated.
Erik
RE: What is st6wf13.5? What is the flange/web size?
I think you got it.  It is almost certainly a structural T cut from a W shape with the given height and weight per foot.  I guess you just need to get a European steel shape table from the appropriate era.  Maybe someone at AISC may be able to help.
I presume the shapes are near the ones given for a WT6x13 and WT15x54 in todays AISC manual.  Good Luck
This is likely a structural tee cut from a W12X27 beam... and is 7'-2-1/2" long.  The W12X27 has a 6-1/2" flange width.
Dik
