Torque vs Amps
Torque vs Amps
I want to measure the torque of motor when more load applied on the impeller of motor(application:Rapid mixer granulatot)to determine the %end point for wet granulatin process.is there any source to get torque meter with sensor.
presently iam measuring amps by using ammeter and calculating manuually % end point of RMG.Is it acceptable?
thanks
rybrk
thanks
rybrk
RE: Torque vs Amps
Sometimes I only open my mouth to swap feet...
RE: Torque vs Amps
You can also use a frequency inverter to feed the motor. Vector controlled inverters have an output signal (or can display) the true torque.
Gunnar Englund
www.gke.org
RE: Torque vs Amps
JRaef.com
Eng-Tips: Help for your job, not for your homework Read FAQ731-376
