Pipe Coating for SS316L
Any suggestions for a coating/wrap for buried 316L stainless steel pipe? The pipe is actually double walled with leak detection carrying effluent from an industrial facility. I've seen coating specs for DI and CS lines and I guess I'm not sure why they wouldn't be applicable to SS, but any input would be appreciated.
RE: Pipe Coating for SS316L
Watch your applicators as there some shysters running around.
I would give them a call with all your information handy.
http://www.densona.com/Index.htm
Steve Jones
http://www.pdo.co.om/pdo/
have you think about stainless steel inside and carbon steel outside? it may be cheaper and in some cases more corrosion resistant
rgs
It is an owner's request for the stainless in stainless. I know there are less expensive ways in fact I would have also considered some form of poly. I'm curious about your comment about a carbon steel containment pipe in some cases being more corrision resistant. Would this depend on soil conditions?
CS will usually fail in a more gernalized corrosion mode. It is fairly straightforward to apply coatings adn impressed current (CP) systems to CS.
Most containment systems that I have dlet with use either CS or poly for the outer pipes.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
