Light bulb specifications
Does anyone have a good website where I can look up
light bulb specs...
THings like dimensions mostly...I'm there are standards out there for the bases, bulbs, lengths etc...
Thanks....Ruso
light bulb specs...
Thanks....Ruso
RE: Light bulb specifications
Check website of sylvania, phillips, GE Lighting..any lamp manufactures.
http://www.osram.com/
htt
Turns out not to be an easy google search, all you get are luminaires being called lighting or lamps.
I need it for a piece of old equipment..only marking on it is CM82
I know I can nail it down if I can do a physical search of the bulb...it runs on 6vdc is all I know.
A good source for finding small bulbs and lamps is the JKL components catalog. Try their web site:
http:
While I can not directly help you, but as you can see every little bit of info helps..your description of lamp, narrows down the search field.
MES? LES? something more exotic?
stevenengineering.com/Tech_Support/PDFs/27MAIN.pdf on first hit. Download the PDF, search for "cm82", it's on page 198.
Double contact bayonet bass. Overall length 1.44 inches max, diameter 0.750 inches max. Design voltage 6.5, 1.02 amps, MSCP 6.0, life hours 500, filament type C-2R.
Maybe this helps.
http://www.ledtronics.com/
Keith Cress
