Paint for Urethane
Paint for Urethane
Paint for Urethane
Hello;
I am looking for a flexible, and abrasion resistant paint to be applied to a urethane part. The part is a 13" diameter ball, made with a .25" thick urethane material, duro 40 (approx). So the material will be flexible and we want the paint to adhere to it without peeling off. This ball will also get impacted so the paint needs to be resistant to abrasion.
Any suggestions? Thanks in advance.
http://www.sprdesign.com
http://www.3dlogix.com
RE: Paint for Urethane
Urethane caulk will accept water and oil based paints. Be sure you wait the appropriate amount of drying time for the paint type you intend to use. 2-component urethane paint can be an option.
Good Luck
Luis
