Extracting ODB data in excel/ascii format?
I was wondering if it is possible to extract data for a node set from the field/history output.
Your responses are appreciated.
Nitin
RE: Extracting ODB data in excel/ascii format?
Yes, it is possible.
(i)To output to a ASCII:
In the Visualization Module
1. "Tools" Menu-> Create a Display Group based on the node set you are interested in.
2. "Report" Menu -> XY (for history output) or Field Output
For history output you need to create an XY Data before.
(ii)To output to Excel:
-The easiest way is to copy-paste from the report asii file and use the Excel Import Wizard, assuming you need to this once in a while. You also can copy-paste the XY Data directly from CAE. (XY Data Manager ->Edit-> Select the data in the table and Ctrl+C , then Ctrl+V in the Excel Sheet.)
-You can use ABAQUS Scripting Interface to program some code to output the data you need in .csv format (or using whatever text formatting you want).
I am looking at the abaqus scripting option. could you site me an example for reading nodeset from the odb and saving it in csv format.
There are examples in the
"Abaqus Scripting User's Manual."
For example, you can take a look at the section
"8.5.10 An example of reading field data from an output database"
....but instead of printing the info you can write it to a text file.
