catia-file-translations-what is best format for sw07?
I'M TRYING TO CONVERT SOME FILES THAT ARE ORIGINALLY MODELED IN cATIA. I NEED TO TELL THE SUPPLIER OF THESE FILES HOW TO EXPORT THEM TO GET THEM INTO SW07, SO I CAN USE THEM. SO FAR IGES CAME IN THE CLEANEST, WITH 1 PART COMING IN AS 1 SURFACE, AND THE OTHER PART CAME IN AS 14 SURFACES. THE DIAGNOSIS TOOLS Cant fix it enough. HE HAS ALSO TRIED EXPORTING PARASOLID FILES, AND THEY CAME IN MUCH WORSE.
The question is...Is there a better format that I should tell the Catia dude to convert the files to?
RE: catia-file-translations-what is best format for sw07?
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
I obtained the original CATIA file (V5 is better than V4 but either version will work). I then contacted Capvidia (www.capividia.com)and had them translate the file for me through their FormatWorks software. They have reasonable pricing and FormatWorks can give you a history tree in some cases (the software is pretty cool. They translate the file and provide you with a .sldprt file when their finished. You have the option of previewing the translated file as an e-drawing before you actually purchase the file just to be sure your satisfied.
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 8/12/06)
SW 2006 SP 4.0 / SW 2007 SP 0.0
I have heard this works pretty good.
htt
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
