Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Really appreciate your site. Really good site for learning what others do when they run into problems. You guy's are great!!!..."
Geography
arksurat (Mechanical)
4 Feb 02 21:31
For D category weld attachment of nozzles on 24" Seamless pipe (SA106 GrB shell) which is a better alternative..
RF Pads or Long weld neck Nozzles?
prex (Structural)
5 Feb 02 4:57
Well, this should depend on external constraints.
In my opinion an RF pad should be used only when space or functional constraints exist. A pad requires a larger hole in vessel and in case of damage to the sealing gasket is more difficult to repair.
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
jmagee (Mechanical)
6 Feb 02 16:40
prex is correct...
Additionally, it is going to depend on what will be connected to either the Pad or LW Neck.
Connection the the Pad s a studded connection and for the LW Neck a standard bolted connection.
Typically, a studded connection is used where there is minimum clearance on the component being cnnected, meaning that there isn't sufficient room for a full lenght bolt to be installed.
Hope that this helps you out.
jmagee
esezginel (Mechanical)
13 Feb 02 10:13
As far as I understand from your question, you have a 24" shell and have nozzless to be welded to this shell. Ýf it is true and you do not have any requirement such as specification, customer requirement, process requirement, etc., using reinforcing pads is cheaper than using LWN flanges in order to reinforce the opening.
Close Box
Join Eng-Tips® Today!
Join Us             Close
