Merging bodies
Merging bodies
Merging bodies
In solidworks 2005 how do you merge solid bodies, so that I can run it in cosmos express?
Thanks.
RE: Merging bodies
In an assembly, you can do a "Save As" and change the file type to a part.  This will create a part file where components are turned into individual solid bodies which can be united (if they touch or intersect).
To unite solid bodies in a part, use "Insert --> Feature --> Combine".
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
