Pressure Class Designations for forged steel Socket Weld Fittings
Can anyone tell me if socket weld fittings are available in Class 150? ASME B31.3 references B16.11 for socket weld fittings. This standard covers CL3000, 6000, and 9000 fittings. I've been asked to specify class 150 fittings to reduce cost on a project, but I've searched the internet and can't find a supplier for them which leads me to believe they are either very uncommon or actually don't even exist. Any help would be appreciated.
JC44
JC44
RE: Pressure Class Designations for forged steel Socket Weld Fittings
Class 2000 is called out for Sch 40 as the bores will
match.
The Class designates the maximum non-shock pressure at ambient temperature.
You will find threaded in Class 2000,3000,6000.
Socket weld in Class 3000,6000,9000, and some 10,000.
Forged steel fittings are about the lowest cost fitting around and are off the shelf.
Our last big project used around 2500 forged socket weld fittings (Class 3000).
For our classes we always specify Class 3000 SW or Thrd fittings as per ASME B16.11 in ASME 150# pipe classes.
Success.
Regards, FKE
I thought Socket/Thread-o-lets are designated by a working pressure rating, as in "3000#" where "#" means LBS/IN^2 not "#" as in "Class, ANSI".
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
I would always purchase forged steel fittings based on the B16.11 Class numbers.
ht
Ambient is defined as: A place where the naked human body can exist for several hours with very little discomfort.
Think ASME not ANSI. Think Class 3000 not 3000 #. I just love having desktop access to download the current standards.
It's very important to use the correct standards, these will guide you as to the required nomenclature.
The ASME B16.5 - 1996 Pipe Flanges and Flange Fittings
This standard covers pressure-temperature ratings, materials, dimensions, tolerances, marking, testing, and methods of designating openings for pipe flanges and flanged fittings.
The standard includes flanges with rating class designations 150, 300, 400, 600, 900, 1500, and 2500 in sizes NPS 1/2 through NPS 24, with requirements given in both metric and U.S units.
The Standard is limited to flanges and flanged fittings made from cast or forged materials, and blind flanges and certain reducing flanges made from cast, forged, or plate materials.
Also included in this Standard are requirements and recommendations regarding flange bolting, flange gaskets, and flange joints.
ASME/ANSI B16.11 - 2001 - Forged Steel Fittings, Socket-Welding and Threaded
This Standard covers ratings, dimensions, tolerances, marking and material requirements for forged fittings, both socket-welding and threaded.
pipingdesigner
www.pipingdesigners.com
Now we know who to aks!
BigInch
They normally met the B16.11 Spec as Class 1000.
Be careful as some imports in this "specification" are no up to par.
I'd take unclesyd's suspicions about these fittings very seriously.
Since you're only using them up to 2" anyway (right?), is there really all that much money to be saved on the fittings versus going with the readily available 3000# stuff? I hate to see material going to waste as much as the next guy (probably moreso), but I must concede that sometimes an over-spec'd standard material is better than a rare "optimum" one.
With your quantity you still might be able to get in on a price break despite the current supply problem.
http://www.alloystainless.com/index.html
