Beginner: Unknown Error
Hi, I am new to using MSC.Nastran. I am running through a tutorial to help familiarize myself with the program. I have created a relatively simple bar with one load with the three translational constraints on each end of the bar, and I am trying to analyze. When I run the analysis the following comes up:
<1> version: 2005.1.2
<2> license checked out
<3> Attempting to read orgs from C:\MSC.Software\MSC.Analysis_Manager\2005r2 ...
<4> Attempting to connect to the QueMgr on Casper:2900 ...
<5> Connection with QueMgr Successful - QueMgr version: 2005.1.2
<6> Loaded configuration from QueMgr on Casper:2900
<7> Wait! Submitting job <bar>
<8> Successful! Job <bar> Submitted ... Job #1 Assigned
Then I go to the completed jobs tab and click on the job I just ran and receive the following at the end of the monitor file:
100 Job Manager...Application had errors.
There is a .tml file that I open which reads the following:
======== MSC (c) 2003 AM TskMgr log file ========
binpath: C:/MSC.Software/MSC.Analysis_Manager/2005r2
orgpath: C:/MSC.Software/MSC.Analysis_Manager/2005r2
user: SYSTEM
version: 2005.1.2
==== < PRE > ====
No external pre program defined.
INFORMATION: No disk space requirement specified
ERROR... Bad card format, card ASSIGN OUTPUT2 =.op2', UNIT = 12, FORM = FORMATTED
ERROR... Pre application error, error = -14
Cannot continue
Not sure what this means....any help could be really appreciated. Thanks.
user: SYSTEM
version: 2005.1.2
==== < PRE > ====
Cannot continue
RE: Beginner: Unknown Error
