Snapping in geopak
Snapping in geopak
Snapping in geopak
Hello-
I am drawing cross section cut slopes in geopak (Microstation V8)using the draw XS line tool and I cannot seem to get snapping to work.  Has anyone else had this happen and know a way to get snapping to work in geopak? Thanks.
-AJgeo
RE: Snapping in geopak
Have you checked you design settings and attributes? Start there and see. You can also use your normal line and make it snap. Some of the tools in GEOPAK have the same properties as the Tools on the Main Palette try those as well.
Namdac
