Sketch dimensions don't display
I’m running SW 2006 on a 3 GHz P4 desktop with an nVidia Quadro FX 1300 graphics card.  2 GB system ram, 64 MB vram, 2 CRT monitors: monitor 1 = Mag 19”; monitor 2 = Mag 17”.  I use monitor 2 only for the AutoCad text screen, but it is always on – i.e. I always leave the nVidia set up for 2 monitors.  I often run SolidWorks, AutoCad, Excel, Firefox, Thunderbird, and Word at the same time.  I have the standard nVidia/SolidWorks settings turned on.
Often, but not always, when I enter an existing SW sketch, dimensions do not display.  If I drag the cursor over them, they display and stay displayed until I try to edit one, or change the view in any way.  As soon as I double click on one to edit it, all the others turn off again.  This does not always happen – sometimes dimensions display and edit normally.  I updated the nVidia driver recently and this did not help.
Any ideas why this might be happening?
RE: Sketch dimensions don't display
I have only seen that once, on SW 05. I had to do a reinstall to fix it. Others may have a different fix.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
The problem you describe is usually caused by an incorrect driver or one which has not been installed properly.
See FAQ559-1194 and the last few posts of thread559-167360.
"I updated the nVidia driver recently and this did not help."
So you are now using the 7756 driver? and the 7184 driver gave the same problem?
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
